Brake Line Service
Brake Line Service
OTC has released a new tool that should make brake line/hose removal much easier! They have a set of locking flare nut pliers available under part number 6720. Here's the link;
https://www.otctools.com/products/flare ... -plier-set
klweimer
Re: Brake Line Service
Post by klweimer »
Sweet.
shmoky
Your car is a: 1980 Spider 2000 Pininfarina
Post by shmoky »
Very nice. What size do we need for our cars (1980)? Or do we need the full 3 piece set?
shmoky
Chetwynd, B.C. Canada
1980 Pininfarina Spider 2000
Sold: 1968 Corvette Coupe BB to buy the Spider
well, the 3 piece set would cover the larger sizes for the hex on the hoses, but only the small size would be needed for the hard lines. Each plier is available individually
coopertl
Your car is a: 1975 124 Spider + 1974 X19
Post by coopertl »
I've had good luck using the Vice Grips (Irwin) 4lw that employs the same principle as the OTC pliers. The 4" pliers work well even on rounded brake line flare nuts.
v6spider
Post by v6spider »
That's awesome Mark!
http://www.v6spider.com
DieselSpider
Post by DieselSpider »
coopertl wrote:I've had good luck using the Vice Grips (Irwin) 4lw that employs the same principle as the OTC pliers. The 4" pliers work well even on rounded brake line flare nuts.
The Irwin Vice Grips have the added plus of a decent cable/rod/bolt cutter built into them. They quickly become a favorite go-to tool.
Here is the link. I have also been using these for years and love them.
https://www.amazon.com/Tools-VISE-GRIP- ... B00004SBBD
the new OTC pliers will prevent those "rounded off" brake line nuts. Traditional vise grips can crush the nut, causing it to be out of round. My set of the new pliers arrived and I'm quite impressed with them
DieselSpider
The ViseGrip 4LW and 7LW are not the traditional locking plyers with the arced toothed jaws but are specially built locking wrenches for hex fittings with a one size fits all wedge style smooth jaw.
That is the tool I have been using. Fantastic gripping power. Still can take a lot of patience, penetrating oil and turning back and forth if the fitting is rusted to the line.
DieselSpider
I have two of the smaller 4LW ViseGrip Wrenches and they are my goto tool now and always in the tool tray I take with me when I crawl under. When I find something stubborn or I do not have the exact size wrench in the tray they can save the day being useful for more than just brake lines and are extremely heavy duty. On a rounded off fitting, nut, bolt, etc that someone else has messed up they have saved me from having to find an immediate replacement and put me back on the road a number of times already.
